Hi,
Im using the TMPEnc beta program. I'm following the step by step instruction to convert Divx to VCD. The problem I['m encountering is #2 on the beginning of instructions. It says "Hit the button Load at the bottom right and load the VideoCD:. The problem is I have no VideoCd choices. How do I resolve this? Thanks for any help in advance.
The templates came with TMPG. Browse to the directory, where TMPG.exe is located. There is a template subdirectory.
Hey Truman
That makes me feel braindead! Thanks you for your help. I rally appreciate it. Do you know if this will then work on most DVD players? -
I believe most DVD standalone players will play vcd. I burned a short vcd and svcd file onto disc and took it to my local store for testing before purchasing a panasonic model. Works great.
Brent -
You must know, what kind of mpeg you are going to create. Let's say, you want a standard VCD, then choose Video-CD(PAL/NTSC/FILM).mcf. If you want a kind of XVCD, choose Video-CD first, then EXTRA> unlock.mcf and change whatever you want.
What will work on most players...I think, Standard VCD will do. Probably you want to know, what will work on YOUR player. First check out http://www.vcdhelp.com/dvdplayers.php
At next experiment a bit and figure it out. There is no general answer, because every type of dvd player is different.
recording from a cam in front of stage
By smartel in forum AudioReplies: 5Last Post: 7th Jul 2011, 08:45 -
XP chkdsk stops at 56% on stage 4 of 5...
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 17th Jul 2009, 00:11 -
Electrical Requirments for Church Sound Stage Setup
By GT Music in forum AudioReplies: 4Last Post: 6th Feb 2009, 14:45 -
editing stage question
By ht0160 in forum EditingReplies: 3Last Post: 2nd Jun 2008, 11:04 -
Capturing AC3 - Stage Two
By Nelson37 in forum AudioReplies: 2Last Post: 11th Nov 2007, 09:01
