I connected my coaxial from my digital cable converter to my AIW 7500 because I wanted to try to capture from cable TV.
I let it recognize the channels, which it did (it recognized every channel) but all channels appeared black.
Is this a problem because it is "Digital Cable" and it goes through a converter, or what? I tried to take the signal before it goes into the converter as well, same problem.
Any experience with this?
Andy![]()
drewson99,
Your ATI 7500 cannot descramble scrambled cable signals. You will need to switch to channel 3/4 (same as your TV) on your ATI to view.
D -
You can connect using the RCA cables as well and the TV will let you change channels that way.
Have you had an problems with capturing sound ?
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 15:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 12:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 14:01 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
Cable video capture problem
By spork985 in forum Capturing and VCRReplies: 9Last Post: 23rd Dec 2007, 14:59
