ok im trying to burn a dvd-r using an mpeg-2 file that i multiplexed ac3 audio into. now im wondering, can i use any authoring program to burn this mpeg now or do i need one that supports the ac3 audio stream? if thats the case, which authoring programs support it? thanks.
Roxio VideoPack 5.0 accepts muxed MPEG-2/AC3 files but is very fussy about the encode/mux settings you use. (And it's quite a difficult program to master.)
SpruceUp accepts 5.1 AC3 files, as long as they are elementary and have exactly the same filename as your M2V files. Unfortunately SpruceUp is no longer commercially available.
ReelDVD accepts 5.1 AC3 files but it's v. expensive and only runs on Win2K.
DVDit PE accepts 2.0 AC3 files only.
Hope this helps.
C h a o j i -
doesnt sound like there are really any good options for this...too bad. it would be nice if there was a program that could just take an mpeg and convert it to VOB files, then i could just burn it with nero. oh well, thx for the suggestions.
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 15:22 -
burning and authored mpeg to dvd?
By just in forum Newbie / General discussionsReplies: 21Last Post: 12th Dec 2008, 10:06 -
MPEG burning
By aruwin in forum Authoring (DVD)Replies: 2Last Post: 20th Aug 2008, 06:02 -
No audio when burning a MPEG-2
By hostofsorrow in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2007, 09:13 -
Edit mpeg and burning
By Mange Muck in forum Newbie / General discussionsReplies: 3Last Post: 16th Aug 2007, 15:16
