Im having problems ripping the widescreen version of harry potter it wont rip the 5th vob file am looking for some answers as to why i cant rip it. Dvd drive works fine too. Let me know if anybody has an answer for me
later
SIn
Results 1 to 11 of 11
Just ripped it fine with smartripper, no problems no errors. Haven't done anything with the files yet.
It always dies ripping the 5th vob file my dvd is fine ripped another movie with no problem. I use smartripper and tried a few others with no luck
Post the error (if any). It may help shed some light on the source of the problem.
it doesnt give an error it just keeps trying to read the disc on the 5th vob and doesnt do anything
Rule out all obvious problems:
>Check DVD. Look for smudges, scratches, etc. Clean & try again.
>Try another 'ripping' tool. (DVD Decrypter or vStrip 0.8f_css)
D -
I noticed that when I ripped it (SmartRipper), vob files 1-3 are 1GB each, vob 4 was like 350MB or something like that, than vob 5-end were 1GB again. Strange. But it did convert fine and it was complete.
SIN, if you're ripping the whole thing into 1 file, depending on your OS or filesystem, you may be hitting the 4GB filesize limit. -
SIN, donīt try to rip the whole disc to only 1 VOB. It's a really large movie and you are most likely reaching the filesize limits.
Rip it to 1 Gb splitted VOBs instead.In this industry, Sadly, The future was yesterday. -
there is no error with the ripping software or dvd drive U R using the fact of the matter is that the DVD is faulty!! if U bought it on the day of release U have the bad version which I had!! The dvd locks up at 59 mins up over on my dvdplayer & also refused to rip, Take the dvd back if U can & get another copy it should work... Mine cam from asda & after a replacement it ripped fine!! BTW the 5th vob was where mine refused to get to!
Kev! -
Phone Warner Home Video on 020 8948 5345 (A London Number) and tell them your disc is faulty. A complete batch went out faulty. The second disc doesn't play on most DVD players. They will send you a replacement free and also a complimentary copy of "Willy Wonka & The Chocolate Factory".
Harry Potter 6
By Drerunsit in forum Newbie / General discussionsReplies: 13Last Post: 17th Jun 2011, 12:23 -
Can't Rip Harry Potter Movies
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 16th Dec 2010, 06:06 -
I keep thinking this can't be right - 7gb for 1080p? Harry Potter movies
By AndyD in forum Blu-ray RippingReplies: 7Last Post: 17th Oct 2010, 08:45 -
Problem with Layer 1 & Harry Potter
By Jeptha in forum DVD RippingReplies: 0Last Post: 1st Sep 2010, 22:04 -
Download the Latest Harry Potter Movie: Legally!
By dvd3500 in forum Latest Video NewsReplies: 14Last Post: 26th Oct 2007, 12:53
