We have a family reunion tape and want to copy it to another VHS tape, but don't know the instructions for hooking together two VCRs. Can someone help?
Just get two vcr's
VCR 1:
Use the F cable (similar to the Cable line that comes in from your cable box) into the IN. On that same machine, from the OUT another F cable to the IN on VCR2:
VCR 2: From vcr 2, F cable from the OUT to your TV set.
Turn on tV, Change it to channel 3. Pop in your original in VCR 1. Pop in you blank on VCR2 . Make sure VCR is on channel 3, Hit play on VCR 1 and HIt Record on VCR 2.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 02:09 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
