Using release 1.09 of DVD2SVCD, Win XP, Fireburner...this is the log from FB.
Thread1: Executing
Recording device: PLEXTOR CD-R PX-W2410A
Firmware version: 1.03
Recording method: Disc-at-once 16 (Dao16)
Recording Speed: 20x
BURN Proof: Enabled
// Burning - data is being permanently written to CD
Thread1: Setting Write Parameters
Thread1: Reading Disc Info
Thread1: Start LBA is -11849
Thread1: Processing Lead-in
Thread2: Executing
Thread1: Processing Track 1 Pause [150 Sectors]
Thread1: Processing Track 1 [Mode2] [545 Sectors]
Thread1: Converting from Mode2/2352 to Mode2/2368 on the fly
Thread1: Autocorrecting sub-channel
Thread1: Processing Track 2 [Mode2] [358820 Sectors]
Thread1: Processing Lead-out
Thread2: Write Error @ Sector 364387
Thread2: Sense Error: ILLEGAL_REQUEST (INVALID FIELD IN COMMAND PACKET) (0x05 0x24 0x00)
Thread2: Synchronizing Cache
Recording complete
But it doesn't work...what is the problem here?? What is the Illegal request line? Bin/Cue are on HD, but I can't burn. Nero says file is to bing and FB can't burn successfully. Any help would be appreciated. TIA!!
I'm no wiz with cue script files so I can't actually tell you what is wrong. But I can tell you that the cue script files generated by DVD2SVCD work without a problem in CDRWin Burning software. I think it has something to do with the Chapters that Fireburner doesn't like.
EC - I have tried like crazy to get CDWRIN to work with my system. It doesn't find the PLEX 24/10/40 , so I don't use.
JX - I would use nero, but it says file size to big. I notice when it goes to the writing stage it says file Size 1603 mb (why I have no clue). I am only loading in one of the 2 cue files. Any advice here? I would rather use Nero, but I can't get this thing figured out.
Thanks for the help m8's
I'd burn using daemon tools...there's a guide over on vcdeasy.org, dvd2svcd.org and also it's contained in the Q&A which is linked in your About tab in DVD2SVCD program namely Q61.
Manfrog,
What version of Nero you are using?
I had exactly the same problem with version 5.5.4.0
Update Nero to latest version 5.5.8.2
This should work fine.
Thanks,
Joey -
Joey m8, I owe ya one...that tip solved the problem m8
I just now need to get the damn CCE logo of the rip. Thanks again
Building a PC for Video Editing/Encoding - Need Advice plz!
By MaTTuP in forum ComputerReplies: 9Last Post: 6th Nov 2010, 10:37 -
I need some advice, problems with the sound becoming offtrack
By maverickboy2007 in forum Newbie / General discussionsReplies: 7Last Post: 16th Nov 2008, 05:04 -
ADVICE needed plz! As of Feb 08, best format to ripp DVDs? TIA.
By carapalida in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2008, 11:11 -
Need Advice for Video Conversion PLZ
By unknown7 in forum Video ConversionReplies: 4Last Post: 15th Jan 2008, 21:22 -
PowerDVD playback problems Plz help
By ian curtis in forum Software PlayingReplies: 8Last Post: 25th Oct 2007, 03:40
