Which quality is better? VCD or VHS?
i found that copy video to VHS from DV is a lot better than make Mpeg1 (VCD) from DV..
sure,if you copy from a digital camera to a vhs,the vcd I think is ideal to copy dvd movies
Rigo.F -
Unless you own an expensive Mpeg encoder, and I am not talking about an AIW card or just using software compression. VHS tends to be higher then VCD 2.0 white book standards. But VCD is still pretty good quality.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Is this VHS Quality Acceptable?
By cfelicio in forum RestorationReplies: 34Last Post: 5th Dec 2010, 14:22 -
VHS to PC quality issues - help please
By carakoz in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2010, 23:17 -
High Quality VHS - Possible?
By Taffin in forum RestorationReplies: 15Last Post: 17th Dec 2009, 00:32 -
avi quality better then vhs quality?
By NateDizzle in forum Video ConversionReplies: 7Last Post: 11th Jun 2007, 09:20
