I have making vcd's now for about 3 months.I use DVD2AVI to get my .d2v and my wav file.But the last two DVD's i ripped and used DVD2AVI to get my .d2v file also produced an mpeg audio file with a delay of -66ms.Can anyone tell me what this means? and how if effects my final encode using TPMGenc.
I don't know much about the dvd part but I do remeber hearing something about hte audio having to be just a fraction shorter that the video or something like that so maybe that is why it has the -66ms delay. Hope this offers some explanation
does this mean that when i encode to vcd that when i go into TMPGenc and you have the ability to select source range that i should set the audio as well to -66ms to get the final mpeg to sych right?
Yes, i think that is what you do if you are using an mpeg audio as your audio imput file. If you want to use a wav file, you have to select the AC3 track in DVD2AVI, just change audio track in the program and then play the movie in DVD2AVI for a few second and it should tell you what audio format the audio channel that you have selected is in the information window. Hope that helps
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 08:52 -
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 22:24 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Will the QT MPEG-2 Playback addon help my no MPEG audio on vegas problem?
By Nuke Shower in forum Video ConversionReplies: 5Last Post: 9th Apr 2008, 16:01
