Im Trying to convet a Dvix with VBR audio. I have tried to use nandub and spliting the audio to wav and the video then joining it with TMPGEnc plus and the sound is 3 sec out of wack. is there a way to convert the VBR back to regular sound.
i have converted several dvix's with no problems. If i use the same methouds i get no sound (tmpgenc cant see the audio).
If you could help me i would be verry happy thanks in advance.
i am having the same problem and actually just posted a new topic for it. it has happened on the last several avis i have tried to convert. Hope we can get some help
You should not be trying to correct bad sync - you should be stopping it occurring in the first place! VBR audio needs extracting as an uncompressed wav before running through TMPGenc.
http://www.vcdhelp.com/virtualdubaudio.htm -
Thanks for the quick responce. Im encoding now. I'll let you know how it comes out later.
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
Convet DVD from PAL to NTSC
By chicodesouza in forum Authoring (DVD)Replies: 4Last Post: 23rd Dec 2008, 03:28 -
HELP ANYONE! i cant convet my H.264 MKV to an AVI
By rod05 in forum Video ConversionReplies: 1Last Post: 15th Jul 2008, 02:15 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 09:54 -
Encode to audio with VBR?
By GangstaRap in forum Video ConversionReplies: 2Last Post: 27th May 2007, 09:56
