OK,
I am VERY new to this, I just figured out how to burn a music cd after 6 months of having a cd burner. I managed downloading a "decent" copy of a big budget sci-fi movie, and it is eating up my memory. The files are 718,190 kb and 649,657 kb. I cannot get them on a 700mb cd-r. Can someone please explain, like you are teaching a 5 year old, how to burn these on a cd-r? I have Roxio 5 platinum. Do I need other software in order to pull this off? Is it possible to burn these so they can be played on a PS2? Help me knowlegable forum browsers.....you're my only hope.
I forgot to mention, not sure if it matters, these are the mpeg versions. Not sure if that is where I am running into problems.
you will have to make it into a vcd just use the vcd templates with TMPG and no PS2 will not support vcd.
If your files are already mpeg,then you can copy the 649,657 kb on empty cd and will play in your dvd player,the other one wich is bigger,you can use Nero and enable "overburn"
Rigo.F
Making a 1 gig HD wmv file to smaller portions
By OzzyWeb in forum Video ConversionReplies: 5Last Post: 28th Mar 2010, 12:10 -
making an avi file smaller to burn
By enigmatic620 in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 09:29 -
how do i make a file smaller?
By Sanosen in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2007, 23:57 -
Making file smaller in Adobe Premiere Pro
By JustinBaker in forum EditingReplies: 2Last Post: 18th Sep 2007, 16:07 -
How to make an audio file smaller?
By aruwin in forum AudioReplies: 13Last Post: 29th Jun 2007, 23:01
