My understanding is that the Hauppauge PVR does not capture true MPEG2. I've tried using the different settings (4bit, 8bit, SVCD SP, etc.) but cannot get TMPEGenc to accept the files created (gives an unsupported format error).
I've read numerous forum posts on the subject, but nothing seems to work.
I just want to record MPEG2 quality video and burn to CD.
Thanks in advance.
Did you try to use TMPGenc MPEG tools to do a remux?
Did you go to www.shspvr.com to check for a solution?
See http://www.shspvr.com/howto/pvr880/wintv_mpeg_%20recording.htmlPanasonic DMR-ES45VS, keep those discs a burnin' -
Yes it capture true MPEG2
As for TMPEGenc 2 thing you need for it to accept the files.
1: MPEG2 codec (Good lucky fine it look like they where remove from here try install the Nimo Codec pack I think it has what you need)
2: TMPGEnc MPEG2 Plugin.
Your 2nd Option is Womble Multimedia Mpeg2vcr 3.12 and 3rd Option is Ulead VideoStudio 6.0 and ther always the Hauppauge WinTV-PVR Editor I just post a newer ver try it out. -
If you import your file into the MPGEditor supplied, it will output a muxed file.
Hauppauge HD PVR
By Susan_T in forum Newbie / General discussionsReplies: 1Last Post: 21st Nov 2011, 16:20 -
WinFast PVR captures audio in PCM only
By jaceko in forum Capturing and VCRReplies: 4Last Post: 13th Sep 2009, 17:24 -
hauppauge hd pvr/5.1 captures
By romanticwarrior in forum Authoring (Blu-ray)Replies: 5Last Post: 9th Jun 2009, 11:37 -
Hauppauge HD PVR
By karebo in forum DVB / IPTVReplies: 13Last Post: 6th Jun 2009, 09:57 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 10:04
