Hi,
Can anyone tell me or point me to a link which can tell me, what is the best format to download from the internet to create VCD's...
I have tried Divx and converted to mpeg using TMPGEnc and virtualdub for the audio.........then burned to disc using nero or easycd creator, and wondered if this was the best way of making high quality VCD's...........??????
If not what is....??????
Ade![]()
Well, unless you can download a couple of gig's in the size of VOB files, or maybe get some high quality MPG or maybe even SVCD files, but then of course you won't need to do any encoding.
I suppose your last option is downloading DivX in highest quality as possible!Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Hello guys,
Can you please tell me how many VCD formats exists? I recently purchased a sony DVD player(region 2) and I wish to play a vcd. I do posses one VCD movie and I am unable to play it as the player cannot reconize the format.
Thankx -
I beleive there is only one,you should read in your dvd player booklet,in my specify that can play "video cd" wich is mpeg1.
Read the operating Instructions and find with wich formats is compatible.Rigo.F -
As Rigo said, there is only one VCD format, the rest are non-standard hybrid alteration of it.
I suggest you check if your DVD Player is capable of reading CDR media as in most cases all DVD Players can play VCD, but not all can read CDR's.Email me for faster replies!
Best Regards,
Sefy Levy,
It seems the more you pay for a DVD player, the less they play.
Sony seem to be particularly bad, particularly in being fussy about the medium, if not the format.
Newsgroups are a good source of VCDs, either in alt.binaries.vcd or alt.binaries.movies.divx. A good DivX converts to a good VCD.
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
