Hi,
A friend is letting me borrow some DVD's tomorrow and I have a few questions before I get started. Firstly, I want to keep most DVD's to just one CDR CD, however, if I really liked the movie then I'll put it on two CD's. I've read the DVD to DivX rip (http://forum.vcdhelp.com/userguides/78732.php) and am wondering if that is the best method? Also, I've downloaded some good DVD rips that are in DivX and im just wondering how they are kept under the 1 CD limit because the quality at a 16:9 ratio is really superb, are they increasing the video quality and decreasing the audio quality? If so then that is what I would like to do with mine, I would like to keep them at the following:
Video quality - 2/3
Audio quality - 1/3
And finally, if the DVD to DivX rip is the best should I use the new 5.0 codec or the 4.11 codec? Thanks.
Results 1 to 1 of 1
best cd ripper
By jason in forum Newbie / General discussionsReplies: 20Last Post: 14th Apr 2009, 15:32 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 14:08 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 17:48 -
various time codes on miniDV. Want one time code.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 22:08 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 01:15
