Hello all
I am trying to capture the Worldcup with my AIW8500DV. At first I was using the example from one fo the user guides here http://www.vcdhelp.com/ATI_AIW_Guide.htm. But still the Video is a lil choppy. It is clear in small screen but when i make it full screen its a lil choppy and i can see small blocks around the players and around the words. It looks fine when I look it at. but when i leave it recording, and view it the next day it doesnt look good. I want to record for vcd format, so that way i can burn them. Can some one please give me the correct setting i should use, so i can record the worldcup while i sleep. Is there any other software that will let me do this?? Thanks to all for any help
el loco
I'm trying to do the same thing and having the same problems. Anyone have any insight?
There are a number of alternatives here. I think your bitrate is too low and therfore the blocks around players and words. I too have been capturing the world cup. I have been using 2 methods.
1) Capture MPEG1: 352x240, bitrate 2400, audio 224 (can use fro 128-224). Capture only I frames (because of lots of motion). I can fit 45 minutes + extra time on one disk.
2) Capture MPEG2: 320x240, bitrate 2500, audio 224. Quality is EXCELLENT!!! To burn as VCD, I re-render in TMPG to VCD specs. Resulting output is better video quality than in step 1. Burn on 2 CD-R. Quality excellent, but obviously takes longer.
I use Visiotek Xtasy Everything on P3 500MHZ 128MB RAM Win98SE. -
If you are going to re-render captured video from an ATI card, you are better off capping at a much higher bitrate (at least 8mbps) I Frame only and use TMPGenc to convert this down to VCD or SVCD bitrates. The quality will be much better than trying to grab directly to low bitrate files with MMC 7.6.
Trying to convert World Cup game to DVD, have a ? about frame rate
By Roge in forum Authoring (DVD)Replies: 8Last Post: 10th Sep 2010, 07:06 -
Anyone watching the Stanley Cup finals? GO WINGS!
By yoda313 in forum Off topicReplies: 7Last Post: 6th Jun 2008, 23:16 -
PC World Article:
By wtsinnc in forum DVD RippingReplies: 4Last Post: 19th Jan 2008, 08:28 -
Question about software for K-World Video Capture Card
By cooper101 in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2007, 14:49 -
2007 Stanley Cup Playoffs
By Grimey in forum Off topicReplies: 23Last Post: 4th Jun 2007, 10:50
