Hi all, a quick search of the forum didn't exactly answer my question... so I figure I will ask.
I am using the ATI All In Wonder 8500DV with the Ulead VideoStudio 5.0 that came with it. My problem is when I capture videos from my VCR using the cables, my files sizes for a 21 minute mpg are 364MB. I have downloaded similar videos in mpg and they range 50-80MB for the same length of time.
With Ulead VideoStudio 5.0 how can I change this? Or should I use a different program?
Thanks!
If you need machine specs, here they are:
WinXP Pro
PIII 866 / 512MB PC133 / ASUS CUSL2-C
C: 10GB ATA66/5400rpm / D: 6X DVD-ROM / E: 80GB ATA100/7200rpm
when capturing direct to mpg the file sise is smaller then if you capture to an uncompressed avi, witch is wery big. when I capture I use motion-MJPEG, a 2 houre movie is about 10 GB, at quality 18 (12:1).
so capturing direct to mpg with out a hardware compressor, the file sise wille be bigger.ChRaN :-)
File Sizes
By rhodellf in forum Newbie / General discussionsReplies: 7Last Post: 18th Jun 2009, 13:51 -
Differing File sizes from same content
By wozmac in forum Video ConversionReplies: 5Last Post: 13th Mar 2008, 10:45 -
Different sizes reported for same file
By Richkut in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2007, 16:45 -
Wrong file sizes in Nero
By jhan in forum Authoring (VCD/SVCD)Replies: 5Last Post: 7th May 2007, 08:27
