  1. Hallo,
    I've burnt my first VCD after editing in VV3.
    I use Nero 5.5.8.0., CD-RW CRX1611
    When i play the mpeg1-file(rendered VV3) on my pc, i get no problem with the audio/video synchro. But burned to a VCD, i get no synchro ! Even in my home-dvd-player.
    Strange enough, when i burn the mpeg2-file(same film)to a SVCD, i get perfect audio/video synchro. !
    Nero ? My CD-RW, Mpeg1-encoder ?
    I appreciate any help !
    Danilo (newbie)
  2. Extract audio as a WAV using Virtualdub then encode with TMPGE using the resulting WAV file as your audio source.
    "Today is only yesterdays tomorrow"
  3. Many thanks for your provided option !
    So it seems as a not-easy-to-resolve-problem, that i have.
    As i just start using videosoftware, it would be easy if all the simle was functioning well ! I've tried Pinnacle 7, same effect. Something goes wrong during the burning proces !! And it deanimates me to think that i have to search and buy and learn new software.
    But Rome wasn't build in one day !
    Thank you for your reply, i will consider getting TMPGenc and Virtualdub.
    Tuffy
