I want to convert a dvd movie to divx,I was fallowing this guide:
http://www.vcdhelp.com/avi2divx.htm but for some reason VirtualDub keep reading the estimated time and never stop,so I have to shut down the program,also I tryed with a very small file and the same,ther is any other way to convert to divx with a good quality picture?
thanks.
Results 1 to 16 of 16
Rigo.F
1st what program r u using to rip the dvd?
2nd why would u want to save it as DivX?
3rd have you ever had problems burning a vcd from a DivX file?
DivX is a problem format.
many divx files need to be demultiplexed (sound and video split) to burn to vcd, and sometimes the sound is out with the video.
Save to standard avi or mpeg -
If you want to create a VCD, don't use DivX as your AVI compression.
Try to make a straight MPEG from the DVD or, convert the AVI to MPEG when you finish your DVD Rip. -
Browner,what I am trying to do is record movies that are hard to find in south america and put them on Kazaa with a specific name,so my family can download them...also family videos,I know the best format is divx because the final size of the movie is going to be very small..
I can convert to vcd and I'm getting very good results,but converting to vcd is not the problem,the problem that I have is that when I want to convert to divx,VirtualDub wont stop doing the "stimated time" the guide here http://www.vcdhelp.com/avi2divx.htm is very simple but in my case wont work.I did many test with avi and mpeg as well.
Maybe I don't suppost to have Divx Pro Codec and Divx mpeg4 codec install..????
Also I know how to convert to vcd from divx,that is not a problem,the problem is converting to divx,I red in this forum that VirtualDub is the best to make divx but not luck it all.
thanks.Rigo.F -
when I convert to vcd I use SmartRpper then DVD2AVI,then I use TMPGEnc,then I burn the cd with Nero,I copy Harry Potter in vcd and the picture and sound is super
Rigo.F -
http://www.doom9.org/guides.htm
You wanna encode to DivX? That link has all the info you need.
Enjoy!
Rigo, once you burn to avi you still have to convert to Mpeg. Which format are you converting to, and do you have a step by step guide. I would really appreciate it.
I am trying to convert to divx,I was fallowing this guide:http://www.vcdhelp.com/avi2divx.htm
Rigo.F -
I guess the correct term to use is Rip from dvd to divx,I found this guide but all the tool links are dead
here:http://forum.vcdhelp.com/userguides/78732.phpRigo.F -
well,I don't want form vcd to divx,I think I found this one wich is from dvd to divx but most the tool links wont works.
You want to Rip a DVD? You want to encode to DivX with the best possible quality? Then head over to Doom9's and do your homework. -
I don't see any dvd>divx guide there...but I found this one in vcdhelp.com
thanks for your good intentions anyway.Rigo.F -
Are you blind?
Just click the DivX guide link!!!
Here just click this poor baby....
http://www.doom9.org/divx-encoding.htm
How to convert TS into AI (DIVX)
By spaansebrabander in forum Video ConversionReplies: 2Last Post: 2nd Apr 2012, 04:38 -
how to convert divx to dvd
By redwolf28386 in forum Video ConversionReplies: 22Last Post: 25th Aug 2007, 07:33 -
Convert Divx
By didikai in forum Newbie / General discussionsReplies: 1Last Post: 21st Aug 2007, 12:22 -
How to Convert 1280*720 DivX to a less dimensions DivX
By firas_hashim in forum Video ConversionReplies: 9Last Post: 27th Jun 2007, 08:33 -
convert divx to quicktime
By Shaorin in forum Newbie / General discussionsReplies: 8Last Post: 23rd May 2007, 07:03
