I keep getting random error "Invalid Block Address" when burning CD's with Nero. It usually happens in the middle of a burn, although the simulation goes fine. If I try it again, it may work or may give me the same error. Ive tried it at slower speed (4x) and had the same problem. Anyone know why this would happen?
this might be a given, but have you tried other cds? does this only happen with SVCD's burns or normal ISO's as well?
Yes this is the 2nd set of CD's I had problems with.. It seems to work about half of the time.. I may have a problem with the drive itself..
try using cdrwin or easy cd creator just to see if maybe nero is having trouble with your drive.....honestly, i love nero and have never had one bad cd out of 200-300 cds burned so far. also try vcdeasy....i love that program....
Restart you computer with the disc already in the tray. Then try to burn again. It surely will do. If not, reinstall your ASPI layer. Are you running XP?
In this industry, Sadly, The future was yesterday. -
Yes Im running XP. I updated the firmware on my Pio DVR103 drive and it seems a little better, but still happens. Yesterday it burned half of the CD, and then stopped and said "This CD is not a CD recordable".
ImgBurn Error "Logical Block Address Out of Range"
By SoberWarlock in forum Authoring (Blu-ray)Replies: 3Last Post: 4th Dec 2011, 15:37 -
How to trace an IP address ?
By susie in forum ComputerReplies: 11Last Post: 21st Dec 2007, 09:08 -
Can someone give me the address for this video? Please... :(
By msmkrck in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2007, 11:57 -
Clonedvd error"invalid block start code"
By demonwarrior in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 05:01 -
Changing my IP address?
By Akabane Kurodo in forum ComputerReplies: 24Last Post: 7th Jul 2007, 08:28
