My current download rate is 1kb/second. i know this is very slow although i only have dial up connection does anyone know any way i can improve my download speed?
wasup
Well if your pulling it off a p2p try to pull it off of somebody with a higher rate like proboly up to 40 becuse any higher wont make a difference becuse you can only pull so fast.And if your wanting to pull audio use kazaa light as the regular kazaa wont let you pull them as fast as you should be.And as far as downloading it from the internet try to get a dowload excelerator it will let you pull a file as multiple connections which lets you pull it faster.
This is proboly a ice cream induced thought so i can not take no control for the above statment. :P -
Download Accelerators are free... (Trials mostly).
Search at CNET, http://www.download.com
Another solution to your problem:
Get a high-speed connection to the Internet!
I use BellSouth FastAcess ADSL and it's awesome!
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
The Vital Message - General Fiction, download ebooks, free download, The
By spacek77u in forum DVD RippingReplies: 1Last Post: 14th May 2007, 02:29
