Can someone tell me how too convert a video compressed with WinRAR into an mpeg so ti can be burned?![]()
Results 1 to 9 of 9
WinRAR is a non lossy form of compression similar to WinZIP. Files are compressed in such a way as the 'exact' copy of the original exists but in a compressed state.
It is odd - no.. very odd for a video to be in this format since is will add to the file size.
Mpeg4 (divx) mpeg1, mpeg2 are ALL forms of 'lossy' (data lost in compression) video compresion. If you suspect the file is still a video then try renaming it with a video extension -> .avi , .mpg, .mpe ...... and see if VirtualDub imports it.
***** WinRAR is NOT a video codec -
i also have a movie in win rar
when i extract it the bin file is 760 mb
i cant get nero to burn the bin or the cue -
I have a video that was put into text format and compressed into winrar. I have tried renaming it .avi .mpeg, but it ends up being .avi.rar.
.rar is like a file with .zip extention, just download the winrar software from www.winrar.com and use that program to extract the original file.
Usualy winrar is used to split up a large mpegs into smaller files wich can be sent through news or email. Those files will normaly be named like .r01 .r02 etc. Just load the first file into winrar and winrar will load the rest by itself (asuming they are in the same directory)
/ Fredrik -
ive done that and then I extracted too another file which when I open has a .bin file and a .cue file which opens up a burn program (Fireburner 2.1.2) which says is burning the cd, but its not.
nero can burn it, FILE --- BURN IMAGE -- load up the cue sheet
movies that are rared up are usally vcd's
if they are avi's then they are usally divx encoded avi's
Rar player
By jimhoofd in forum Software PlayingReplies: 13Last Post: 24th Feb 2011, 14:12 -
files .rar
By marlo in forum ComputerReplies: 13Last Post: 14th Jun 2009, 05:57 -
.rar files
By deadman1972 in forum ComputerReplies: 10Last Post: 26th Aug 2008, 11:37 -
win rar help
By kennyjunior in forum Newbie / General discussionsReplies: 6Last Post: 11th Nov 2007, 12:55 -
multiple rar question
By cloudlight in forum Newbie / General discussionsReplies: 18Last Post: 30th Jun 2007, 23:21
