Hello, hopefully someone can help me out again... I have some divx files that are set to VGA size, and when i convert it to VCD, I loose quite a bit of the picture, which is no fun when you have subtitles on the source file. I am using TPMGEnc, and I can't figure out how to do this. The best I've come up with is by cropping the top of the screen, but there's got to be a better way to do this... Anyone know how I can do this?
I am having the EXACT same problem. Yesterday I made some subbed anime into VCD, and when I tried to play on DVD player, the subs were cut off
But when I view on PC, they are still there.
I made a post similar to this asking for help yesterday; no one has replied though
This might help you guys with your cutting off problems. Follow these steps.
1.) Open TMPG and choose the aspect ratio that exactly matches that of your source file.
2.) Before you begin encoding, go to Settings--->Advanced--->Video Arrange Method and choose Full Screen (keep aspect ratio)
3.) Begin encoding.Visit my webpage at:
http://leech.at/e-z-e -
I have the same problem with VCD's on my DVD player, but not with SVCD's. The problem is the subtitles are in the OVERSCAN area of the video. Most DVD players dont show the top 16pixels, bottom 16pixels, the right side 16pixels, and the left side 16 pixels when playing VCD's on a TV. The solution is to resize the video to this formula: (VCD_width-32)x(VCD_height-32) and then add a 16pixel board around the video.
In Avisynth it looks like this:
SimpleResize(320,208)
AddBorders(16,16,16,16)
This should fix the problem. You can also try 336,224 and a 8,8,8,8. Always try to use multiple of 8 since of how microblocks are used and compressed ( you'll save on bitrate, giving it to the rest of the video ). Oh yeah, make the border black. This is assuming the video you have is full screen 4:3 ratio. Try FitCD, this program will analyze the source video file to the desired destination format and give you the correct aspect and overscan values for resizing - also includes a fix for CCE microblock/overscan bug.
Wide screen (16:9) DV to Divx
By wayback in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Jul 2011, 15:05 -
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 12:50 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 22:57 -
870211 - vcd cut
By hamidi2 in forum Newbie / General discussionsReplies: 2Last Post: 30th Apr 2008, 04:55 -
Cut Divx without Re-encoding
By kman22 in forum EditingReplies: 8Last Post: 26th Nov 2007, 19:39
