hi im new here, just found out about this website today and have been researching. Notice that no one uses roxio cd creator platinum. Well, i have downloaded music videos and use tempgenc to convert it to mpeg format for vcd burning. I use the roxio to burn it to vcd but most of it i cant burn b/c it says SYSTEM CLOCK REFERENCE....not acceptable..please help. thanks
are you using tmpgenc's vcd template?
donwload nero 5.5.8.2 and stick with it.In this industry, Sadly, The future was yesterday. -
That message means that your MPEG isn't multiplexed correctly / incorrect pack size.
If you used TMPGEnc, it means that you didn't load the VCD templates ... which also means that there is a better than average chance that your MPEG isn't the correct VCD specs either.
Assuming that they are, you can fix this problem by remultiplexing your MPEG with something that is aware of VCDs (e.g., TMPGEnc --> File --> MPEG Tools --> Simple Multiplex) or bbMPEG. Make sure that with TMPGEnc that you select "MPEG-1 Video-CD" rather than "Auto" when you remux.
Regards.Michael Tam
w: Morsels of Evidence
H.264 reference frames
By grinder_luck in forum ProgrammingReplies: 1Last Post: 13th Jul 2011, 11:39 -
Unusual behavior of PC clock
By Seeker47 in forum ComputerReplies: 7Last Post: 22nd Aug 2009, 12:34 -
sync computer clock to broadcast?
By 4evrplan in forum ComputerReplies: 5Last Post: 9th Jul 2008, 15:36 -
Fall for Recorder Clock
By UnknownVT in forum DVD & Blu-ray RecordersReplies: 8Last Post: 12th Nov 2007, 09:06 -
Trutech 1620 clock
By jaybird206 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Jun 2007, 14:20
