  1. Hi
    I am using roxio video pack to burn my VCD's.
    Unfortuanately I bought 100 Sony discs but Roxio will not burn to them, I also tried burning a VCD through Roxio easy cd creator but it did'nt work neither.
    I used VIVASTAR blank disks previously and they worked fine.
    What I need to know is, is there any1 out there that uses this program? and what make discs do u use?
  2. I have used several different types of cd"s, including imation and tdk.
  3. I've used everything from TDK to Maxell to Memorex...and all the other cheapie no names without any problem in both Videopack and Platinum.
    Are you sure that it is a media problem?
    Maybe non compliant VCD's your trying to burn?
    "Today is only yesterdays tomorrow"
