Hello,
I have some subtitles from different kind of movies, but
I don't no which framerate the subtitles have. Is there a
tool which can detect the framerate of the subtitles.
As far as I know you have to write a script (sort of EDL) which will tell your authoring software the timecode position for each subtitle page. There are plenty of tools to help you out with it. They are available under the Tools section.
In this industry, Sadly, The future was yesterday. -
pacoreguenga, I am new with this stuff.
Could you give me an example which
program I should use.
thanks in advance
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 17:57 -
how to determine framerate of subtitle?
By pike8 in forum SubtitleReplies: 6Last Post: 7th Aug 2009, 23:06
