use iuvcr to capture, best use with huffy codec(lossless quality)
capture at 352x240 if you want to create a NTSC VCD
dont go higher than 352x240 if you only gona make a vcd cause you wont see the different and it require a lot of spaces to capture at a higher resolution also longer encoding.
SVCD- capture at 480x480
DVD - capture at 704x480
just capture at the resonlution that you gona use to make your VCD, SVCD, DVD.
Results 1 to 1 of 1
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
