Can anyone tell me what the relationship is between the Quality setting (0 - 100) and the bitrate? How much larger will the file be if encoded at 1150 / 100 over 1150 / 65? And, what is the advantage of using A_VBR for Mpg1 as per Sefy's SxVCD template over CBR with a rate of say 1700 or so? Sefy's template seems to be maxed out at 1150 but with a quality setting of 100. Im confused. Won't just upping a VCD's bitrate 30 or 40% just do the trick? or do i need to mess with a_VBR with a max of 1150 and 75 or 100 Quality setting?????
--------->DAZED & CONFUSED BUT HAVING FUN<----------
Results 1 to 1 of 1
Higher 2.0 AAC bitrate from Ripbot
By jntaylor63 in forum Blu-ray RippingReplies: 6Last Post: 3rd Nov 2012, 16:22 -
Xvid Setting: 1pass Quantizer vs Bitrate Mode, vs 2pass => Quality
By carlaron in forum Video ConversionReplies: 12Last Post: 4th Oct 2010, 07:12 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 21:33 -
Will the quality increase if the bitrate is higher after conversion?
By Choppa in forum Authoring (VCD/SVCD)Replies: 16Last Post: 3rd Jul 2007, 09:23
