What procedure or tools do I have to run to put subtitles to my VCD after ripping a DVD with Smartripper? Smartripper creater VOB's. I can't find a procedure in VCDHELP to combine the VOB and *.srt (or *.ssa) as input to TMPGenc.
You cannot add subtitles directly through TMPGEnc.
You need to add two more steps to the procedure:
1 - Rip with smartripper
2 - Use DVD2AVI
3 - convert the movie output with VFAPI
4 - load the VFAPI movie part in virtual dub, and use the "VOBSUB filter.
5 - frameserve.
6 - Load the frameserved movie file, and the audio file (created by DVD2AVI) into TMPGEnc.
This looks like a lot of manual work, but it will take a few minutes.
If you want to know where to download and maintain all the programs listed above, the please check the guides from this site: It is quite well explained...The Dutchman -
Thanks (or dank je gezien de nick "dutchman").
gonna try. Never used VFAPI before.
Herman Hanssen
Netherlands, Landgraaf -
Goedendag Herman,
I have just answered your mail. I hope this helps.
regards,The Dutchman
How to Create Scrolling Subtitles on my Videos?
By devilcoelhodog in forum SubtitleReplies: 6Last Post: 7th Dec 2013, 09:17 -
Create own Subtitles
By kerpal in forum SubtitleReplies: 11Last Post: 16th Oct 2013, 09:19 -
A better way to create subtitles in Vegas?
By Srivas in forum EditingReplies: 0Last Post: 5th Jan 2012, 00:52 -
Subtitles: easier way to create them?
By tirengarfio in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2008, 23:43 -
Looking for a better way to create subtitles from hard-coded movies
By moviebuff2 in forum SubtitleReplies: 4Last Post: 16th Jan 2008, 06:12
