    Apr 2002
    Hi All.
    I think this can be done, judging by what I've read on this website, but can someone confirm this?
    What do I need to do?
    thanks
    Dave
  2. yes it can be done. As to how i think has been one of the most popular q's recently so if you do a search you'll get very good answers some written by ppl who probably know better than me
    hope that helps
    #videohelp on dalnet!
    Apr 2002
    cheers
    must have missed that.
    D
  4. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    Look...of course you can convert em..... They are both just data
    vdc standard is MPEG1 and svcd is MPEG2 just take the file from one and encode as the other...if you just have the svcd disc then the file on there is a dat file if I remember right ...And depending on what program you encode with you might have to convert the dat back to a mpg first....
    But like was said above ...I think one of the how to's will walk you through step by step.....
