I am having a problem encoding a MPEG-2 file with sound using TMPGEnc Plus. I have made a wav file with VirtualDub and even tested the sound in TMPGEnc. However, after creating the file I try to play the clip and there is no sound. I am using the same method as I used to create mpeg-1s (VCD). When I used those it has worked.
Any ideas? I believe have all the required codecs, but could I be missing something?
Thanks.
Results 1 to 1 of 1
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
