Hi, I have a copy of Star Wars 2 on SVCD ( 3 CD's) and it's 797MB on each CD. The CD's it's on are 700MB/80 mins, how can this be????
The file size is saying 797mb and the cd they are on is 700mb ???????
When i try to copy the files my PC says the cd i have has 702mb free and it won't let me copy the files. I am using windows XP to copy the CD's.
Can anyone help me, I also went out an brought some 800mb/90min CD-R's thinking that the files would easily fit but I am still getting the same message - 702mb free on CD ?????
I am new to copying and need some help. Many Thanks
Closed Thread
R U trying to burn it straight to the cd!! if U R well U R doing wrong! U have to burn it as a vcd droping your mpeg into the specified box!! it aint like burning a normal cd. the mpg is either 79 mins if a vcd or if U have the 3 disk svcd this is 45 mins.
Kev!
BTW use nero to burn your svcd's open the svcd template drop the file in and away U go.... sorry for the above but it will help U in the future
one topic is enough
http://www.vcdhelp.com/forum/viewtopic.php?t=94838
800mb avi; Would want it to go onto a 700mb CD
By mark63534 in forum Newbie / General discussionsReplies: 39Last Post: 28th Feb 2010, 19:31 -
How do I make a 700MB+ video file to a 700MB video file?
By riahc3 in forum Newbie / General discussionsReplies: 26Last Post: 2nd Jul 2009, 20:55 -
how to rip 1.4 gb file to 700mb
By stranzer in forum Video ConversionReplies: 15Last Post: 17th Jun 2008, 16:17 -
700MB before subs, 1.12GB after??
By tommy23 in forum SubtitleReplies: 6Last Post: 17th Oct 2007, 22:05 -
cannot make 700mb rips
By zakkwyldebls in forum DVD RippingReplies: 6Last Post: 9th May 2007, 22:43
