Okay, this is the first time this has happened: I've downloaded a clip and tried to serve it with TMPG but there only turns out to be about 15 seconds worth of sound whereas the source file contains sound the entire clip (???) The source reads "divx.real.avi" /// I've tried to convert the clip using dBPowerAmp by changing the file extension to mpg but that didn't seem to work. Might anyone out there have any advice? I'm sure there are those who know exactly which clip it is! Much Thanks!
I figured it out: the audio needed to be decompressed! Used AVI2VCD audio decompresser.
AviSynth audio errors while converting with VDub x64
By klischee in forum EditingReplies: 0Last Post: 16th Dec 2011, 14:25 -
VirutaDUB Interlaced Output and Audio Errors.
By vodmare in forum Video ConversionReplies: 25Last Post: 16th Aug 2010, 07:42 -
Scan Audio file for Errors
By MegaTonTerror in forum AudioReplies: 1Last Post: 10th Oct 2009, 10:45 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
video audio sync errors
By demonwarrior in forum Newbie / General discussionsReplies: 8Last Post: 21st Sep 2007, 07:50
