Hi everybody.
I'm having some problems while trying to play divx movies on PowerDVD and WMP. PowerDVD just exits whenever I hit on play, and WMP just shows a green screen then crashes. I have no problem at all playing divx movies on DivX Player 2.0 Alpha. I'm using Windows XP on an AMD Athlon XP 1900 with most of the codecs installed. Any advise will be greatly appreciated.
And on another note, I'm also having problems trying to encde divx into mpg using Tmpegenc 2.54.37.135, it will either encode for a while then crashes, or at times it will just go on... creating a black screen that goes on for hours after the movie has reached it's end.
These are the codecs that was installed in my system.
