I bought Forrest Gump off of Ebay and it has this yellow sticker on it. I haven't seen this before, and it will not work on my Sony DVP S550D DVD player. It will work on my computer DVD drive, however.
Is this a VCD or some other funky configuration, or is it simply defective?
your player should play a dual layer dvd, but is it from the same region as you (ie north america, europe...)?
It is a region 1 DVD. Actually, I was playing around in desparation and got it to work. I put the DVD in, shut the DVD off, then held down the play button when I turned it back on. Surprise, it worked! However, the picture is not as crisp/clear as my other DVDs. The disk looks original.
But, what is a dual layer DVD and how is it different than a regular one? I've seen dual layer 7 and 9. What's this mean? -
dual layer is actually what it says you've got 2 layers of info on the disk,
the top layer is like a single layer dvd the bottom one is translucent so the lazer can see both. the bottom layer is usually smaller soething like 3 gigs if i remember well. as 2 the 9 i can't seem to remeber right now but i'll look around to refind the info...#videohelp on dalnet! -
MicheleU,
I don't know why you can't get it to work but I think I should point out that most commercialy made dvd are in fact dual layer discs.
Hope this helps
VCD$MEWe were all NEWBIES once and the only stupid question is the one that's not asked?
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 20:17 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
Question about Burning an Entire DVD9 Movie to a Dual Layer
By |-Goku-| in forum DVD RippingReplies: 9Last Post: 30th Dec 2007, 19:41
