How do I compute the start and end frames in TMPGenc for the source range under the Advanced settings?
not sure what you mean by compute, but all you need to do is use the slider and find the point you'd like to beging encoding at, then click "Set Start Frame", then use the slider again to find your end encoding point and click "Set End Frame"...
Hmm? Like Hitechjunki said, just double click on source range, move the pointer to where you want to start stop. Now let me take a guess and add that you want that range to take up the whole CDR and want to know what bitrate to set.
If so use one of the bitrate calculators under tools (on the left). You have to encode with either CBR or 2pass VBR for the calculators to work thou.
Trim MP4/H264 video? Want to remove the start and end - how?
By the loc-man in forum MacReplies: 11Last Post: 2nd Nov 2010, 10:12 -
Trimming AVI in virtualdub,direct strem copy ignores my start and end point
By Rudyard in forum EditingReplies: 4Last Post: 4th Oct 2010, 19:11 -
DVDShrink Start/End
By chronic777 in forum Authoring (DVD)Replies: 7Last Post: 22nd Jul 2008, 12:30 -
where is start/end or seek/duration options
By dr.indiflid in forum ffmpegX general discussionReplies: 0Last Post: 18th Mar 2008, 13:20 -
Trim start and end of MPEG2 compliant video.
By mattstan in forum EditingReplies: 5Last Post: 25th Feb 2008, 10:06
