this is what i found so far, Advc white comes out gray looking,
any ideas?
That happened when I installed a type of Mpeg2 AV Decoder Filter, I don't remeber which. Everything worked fine, but then I downloaded a bunch of codecs, and encoders etc.. to try out with my different capture programs. One day after captureing something from the tv I reaized when I went to play it back, that it darkend everything I played, regardless of what program/media player I used....I uninstalled it (it was an some actual program, and it showed up in my control panel/add-remove programs)it was called...Mpeg2 AV Decoder Filter...so after I removed it, everything went back to normal....I guess it just didn't work well with my advd....but anyway, it might be something like that causeing the problem..otherwise, I don't know
nup.. the point i was showin how the ADVC shows white color as a grayish lookingOriginally Posted by Bluesky22
and in kylies clip the head of that dude has colour blering (greenish arround his head in the zoomed bit where the dc10 dont) -
ahhhhh, sorry, I read it as..got any ideas why the advc comes out grayish vs. with the other two..
Don't know why you get the color bluring or grayish color. The quality I get with my advc-100 is nothing like what you get..mine is much much better.....
anyway...I think I'm just confused, and saw it as a question for help rather than a comparison.sorry
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
