hi,im trying to burn a a movie on cdrw,nero does it ok untill i go to burn. it says sorry but writing mulitisession cds (ie without finalizing) is impossible with the current selected recorder,using this burning mode.
then it gives me the option to turn off multisesson or turn off disc @ once.
can anyone help plz,thx
sound like your burner doesn't suppport multisession on cd-rw for what you where trying to do you might consider finilizing your cd-rws...
you can always erase and rewrite if you want to at a later date -
i think it does, it will burn it but when i pop it into my dvd player it says no disc.thx
well if your not finalizing your cd's it normal that the player doesn't accept them
AVI on CDRW stops playing in DVD player?
By leonk in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2012, 21:53 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 10:55 -
Problem playing DVD-R in several CDRW/DVD
By shortytigg in forum Authoring (DVD)Replies: 7Last Post: 20th Feb 2009, 13:39 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10
