im thinking about buying a tv/fm pci card that is quite cheap (100euro)
They say that it has mpeg1/2 compression hardware inside, and the price is very good if it's true.
the url is :
http://www.jepssen.com/home/vid_aud_hub_eng.html
do u know anything about it ?
the brand is quite unknown (i mean, it's quite famous in italy BUT i couldnt find any info about this card) so i dont know if it's good, if i can find inside a common BT* chip (usable with many 3rd part sw), if the sw is decent and so on...
any idea?
Ecio I ask them what hardware encode chipset there using, USB may have one but from look of PCI it look like a reg TV card.
sorry i havent understood
do u mean that YOU have asked them or that I SHOULD ask them ?
YOU should asked them what hardware encode chipset there using.
a friend of mine took a look to the chips and he told me that these are the models :
conexant fusion 878A
25878-13
E 160846.1
0142 taiwan
Myson MTU8B56EP
0142AHA1K1
(PHILIPS?) HEF4052BT
E2751 07
on the tuner
TLC 2002 MB-1F
2K1 006
any idea?
Hauppauge PVR-350 periodical audio distortion
By frankvnk in forum Capturing and VCRReplies: 1Last Post: 2nd Oct 2010, 09:40 -
HD PVR - Audio not synced with video
By lacywest in forum Video ConversionReplies: 5Last Post: 29th May 2010, 10:20 -
WinFast PVR captures audio in PCM only
By jaceko in forum Capturing and VCRReplies: 4Last Post: 13th Sep 2009, 17:24 -
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 09:26 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 10:04
