How can I convert an XVCD to VCD? Why would I want to do that? For the simple reason that XVCDs are so big that they can't fit on a standard 650/700 MB CD-ROM. I would like to archive an XVCD file, but it won't fit on a CD and I don't have a DVD burner available to me. Is this possible?
Thanks for any help.
Michael
seems to me that reencoding with tmpgenc with a standard template that matches yur source will do the trick, no?
Thank you, Blacklotus. I don't know why it never occurred to me that the answer would be so simple. It worked no problem.
Thanks again!
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
VCD
By dodd22 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2007, 18:01 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
VCD
By rocketboy in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 16:06 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
