  1. Hi, i have a problem. I followed the guide "How to add permanent subtitles with VobSub" (http://forum.vcdhelp.com/userguides/87065.php#5), Scenario 5.
    I have fixed the .ssa file and put it with the .avi file in the program SubMux and then i pressed "Mux". But the problem is that the outpot file just become 244 KB. I canīt see any places where i can do some changes
    either. Do someone know whatīs wrong?
    Thanks.
    Mar 2001
    Somewhere on planet earth
    You should check doom9.org. They have some pretty good guides and software for adding subtitles to your video. There is a GUI for submux called WInSubMus which allows you to add SVCD switchable subtitles. If you can't find them let me know and I'll provide the links.
