Well i am just trying to find the easiet way to convert my SVCD over to DVD-r??? I followed the tutorial and patch my video files... Everything setup right... then i repatch them back and when i select Burn DVD it says incorrect video size... I am useing DVDit PE 2.5.2... it wont allow me to burn it and if i select burn it stars converting its to late to patch it back??
If anyone got this to work... could you please tell me what authoring software allowed you make it..
I also tried the other way of resizing the svcd video to DVD compliant size and it took 20 hours in Tmpgenc... highest quality... and i could tell it degraded the video still...
Can anyone enlighten me for the best and fastest way to convert SVCD to DVD-r???
Rick
Yeah i tried Spruce DVD Maestro 2.9 and it work for me. Like i said before DVDit 2.5.2 it does not work if you patch the files...
|Dirt| -
I used the guide at this site and used SpruceUp to author and burn, with no problems.
If you want to use SpruceUp, go to www.doom9.net or search the 'net for a download. It is no longer sold, but you can download the trial and if you are lucky someone may "hook" you up with a crack -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
DVD with a home made video of a wedding can not get it work on dvd player
By kyrieanddave in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 11:03 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
DVD copying with Nero - demands DVD/RW disc and still doesn't work.
By gorelle in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 04:44 -
Daytek DVDR-P30 what brand DVD+R do you use? my HP 16x DVD+R don't work
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Oct 2007, 22:22
