i'm just learning capturing video and just finisned capturing 9.67Gb 50mins avi video using VirtualDub here's the setting i made
FRAME RATE: 14,990
DURATION: 559,573
DATA RATE: 7552.96 Kbps
VIDEO COMPRESSION: Huffyuv V.2.1.
ATTRIBUTES: 24 Bits, 640x480
TOTAL FRAMES: 8,388
AUDIO COMPRESSION: PCM
ATTRIBUTES: 11.025 Khz,8 Bits,Mono
TOTAL SAMPLES: 32,899.384
and i had ATI ALL IN WONDER RADEON 32MB VIDEO CARD and windows 2000 operating system.
my question now is after i finished capturing from my vcr,i noticed 22% Frames Dropped,is that too much and what setting should i do to get rid of it,i was thinking to encoded with 22% Frames Dropped coz i hate to start over again,but what gonna happen to my video if i encode this to Svcd,please help me guys,thanks in advance
and also one more question about VirtuaDub under CAPTURE SETTINGS
where its says ADVANCE then Dropped limit 10%
next to it MAXIMUM INDEX INTRIES 324000 <------ what is this number for
You are capturing at VDubs default framerate of 15fps. If you are in a PAL area capture at 25fps, and 29.97 for ntsc. I find that if I capture at 15 it drops loads of frames but it is fine at 25.
Craig
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 06:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 23:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 14:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
