I did everything from the FAQ that was under the newbie link but it only plays on my DVD player in my PC, I have a Sony stand alone DVD player that says it only plays certain cdr/cdrw but I have the silver top like it says its suppose to play. The file will only play in PowereDVD, so did I convert the file correctly?? TIA
did you check your player in the compatibility list, to see what kind of encoding you can do? My sony, for example, can only read XVCD 2300 kbps maximum bitrate
and don't forget to make it "non-compliant" when/if burning in Nero -
Have you verified that the brand of CDR actually works in your DVD player. Try copying an audio cd and see if that plays. If it does'nt you know that it is the CDR that is at fault.
Craig
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 01:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 21:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 07:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
