  1. Hello to all! Does anyone know if there is some software that will allow you to copy a DVD without having a DVD player? Maybe something like, 'mounting' the image to a virtual drive or something like that. Anyone have any ideas?
    Chris
  2. Yes indeed. The latest DVD Decrypter allows you to copy a DVD onto your hard disk, using your DVD Rom drive. It can create the disk as an image, which can then be loaded using tools like Daemon Tools to read the image.
    www.dvddecrypter.com
  3. if you have no dvd rom on the computer, then no you cannot copy a dvd, but then the price of dvd roms being so cheap if you are into dvd copies, then you might as well buy one, and if you do Pioneer 115 / 116 is the way to go.
