I'm a bit bummed out. Have a new Pioneer DVR-A04. I burned some data to a Pioneer DVDRW and it works fine on that computer... but the disk it is not recognized on any other system w/DVD drive.
Also, I created my first DVD using Impressions DVD Pro 2.2 (and the Matrox RT2500). The DVD works fine in a Toshiba stand alone player but not on any of the 3 computers I tried that have software DVD players. I burned the TS_VIDEO directory as it said in the instructions. Should I be using a disk image?
Many thanks in advance,
NK
DVD-RW compatibility is roughly around 2/3rds. ie. Not good enough. DVD-R is really the only compatible (-) standard. You may want to invest $50 in a DVD Multi DVD-ROM drive like the Toshiba SD-M1612 (for your other computers) which will read DVD, DVD-ROM, DVD-RAM, DVD-RW, and DVD-R. (I don't have DVD-RW, but DVD-RAM works great with it.)
If your DVD-R doesn't work in any of the computers you should check to see if the DVD-R is recognized at all. ie. If you can browse the disc with Windows Explorer, but your DVD software won't play it, then it's not DVD-R's fault. It's the fault of the DVD authoring/burning software - the disc was not correctly made. If Windows Explorer doesn't see the disc at all then it may be a DVD-R compatibility issue with your drives.
Also, some DVD software is pickier than others. What software and what versions? Have you tried using Windows Media Player? I find it less picky than PowerDVD 3 for instance. -
Check your other systems' dvd drives's firmware version and date. Update if necesary, as DVDRW media compatibility began just a year ago...
In this industry, Sadly, The future was yesterday.
Subtitles - progressive sync and incompatibility (srt and sup)
By sooojaded in forum SubtitleReplies: 3Last Post: 7th Feb 2012, 15:59 -
An MP4 with some incompatibility issues
By danielbb in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jan 2010, 20:22 -
Windows Media Video DRM incompatibility w/ NVidia cards using TV out?
By Bix in forum ComputerReplies: 10Last Post: 18th Sep 2008, 19:36 -
disc incompatibility seg 3000
By bryanmansfield in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Mar 2008, 14:32 -
Encore/Video Wizard incompatibility with high bitrates?
By moxiecat in forum EditingReplies: 2Last Post: 20th Sep 2007, 15:29
