I have a 4cd svcd dvdrip of Lord of the rings. I converted them to vcd compliant MPEG video. I would like to rejoin these since I will not need 4 cds since the vcd compliant MPEG is much smaller in size. If possible I would like to cut it down to 2 cds if possible. Thanks for your help.
Use TPMGe. Under mpeg tools , last tab is cut and join, Choose Standard VCD from pull down menu...click on add and select part 1 then add and part 2....name out put file Something other than what u have already ...then run.. Takes a few...u can watch progress
Joining more than 2 mpegs...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 30th Jul 2011, 09:33 -
Jerky action mpegs
By enfield250 in forum Video Streaming DownloadingReplies: 5Last Post: 23rd Aug 2010, 05:51 -
HELP - no sound from avi's and mpegs
By mstumpf123 in forum AudioReplies: 3Last Post: 17th Jun 2009, 21:52 -
encoding mpegs with cce
By ricky1756 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2008, 11:10 -
How to slow down speed of Mpegs?
By lillei55 in forum Newbie / General discussionsReplies: 5Last Post: 10th Sep 2007, 17:40
