hello all, my first post here. I downloaded a svcd movie and extracted the cue file via vcdgear into mpeg. I'll assum that this is mpeg2 for svcd. However, i want to burn this onto a dvdr to play on my standalone player. Do i still need to convert this svcd mpeg into dvd mpeg or are they the same? thanks for any help.
why not burn it as a svcd and watch it like that? you wouldn't gain any quality by reencoding it for a dvd-r (if fact, you'd lose quality)
can anyone else help? I would burn svcd if my player suppor it...too bad it doesn't...
ahhh, see you never said that your player couldn't read svcds. I just assumed it could. now that i know a little more about your dilemma, try this.
http://www.vcdhelp.com/svcddvdr.htm -
yes, i suppose i can do this....but the problem is my dvd player is 4 years old. It's very picky and supports only vcd, dvd and cd. It's a sony dvp-c600D....So i doubt authoring svcd mpeg onto a dvdr will work on my player. So i guess a final question is, my last resort could be to re-encode the svcd mpeg to a dvd mpeg and burn it correct?
that is correct. I would suggest that you use tmpgenc and use as high a bitrate in the dvd template as you can, also choose soften block noise in the quantize matrix tab. hope that helps.
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
How to convert MPEG-4 into MPEG-2 with a Mac
By VidHunter in forum MacReplies: 12Last Post: 29th Oct 2007, 01:23 -
Convert mpeg-4 to mpeg-1 with ffmpegx?
By CollinH in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 23:36
