Make this a two part rant. homerpez, until DVD writers can be had for less than $100, and blank DVD's for less than $0.20, then it is certainly worth tossing that DVD in the computer overnight to have a copy for $0.40, assuming a two disc copy, for backup purposes, of course. Also, as I said before, copying your fav. TV shows is good too, b/c you can fit approx. 7 or 8 shows, minus commercials on a single DVD, when that becomes cheap enough. Also, there are people out there with videotapes of special events that they would like to archive and share with friends and family. An example of this is a two hour video of poor departed fluffy the cat scratching at her kitty litter. Remember that the fun is really in making the copies, not in actually watching them![]()
TomG. - aka Plant_Guy
Results 151 to 164 of 164
Just to let you all know,
I want dvd compatibility anyway but a res of 720x576 isn't possible on a cd because of bitrate limitation so I am switching the res down to 352x576 and switching back to the old faithful cce. I may try dvd2svcd, but one thing is certain, I have given up on kwags templet as it is useless for me and switvhing to:
352x576-dvd compatible
48khz dual channel 160-dvd compatible
mpeg 2-dvd compatible
15 frames per gop-dvd compatible
this means I SHOULD get a movie on 2cds no prob with cce and be dvd compatible also.
Baker -
quick question..if 702x480 doesnt play correctly on my dvd player, will 352x480 play?
I tried 352x240 and it plays fine but its so small!
I'm trying burn a VCD. -
Originally Posted by baker
If you have good results with CCE, I wish you luck, as CCE can't have a long GOP as it is in the KDVD template. So the file size for an mpeg generated with CCE will be much larger than one created with TMPEG. As quality wise, at 5,000Kbps, there's no visual difference from CCE or TMPEG.
As for DVD compatibility, KDVD mpeg's have already been burned "AS IS" with DVDit 2.5 PE and SpruceUP. They are 100% DVD compliant mpeg files, with the added bonus of a small foot print.
kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
I mean that the max a dvd player can read is 3000 so 5000 wont work for me.
I have just finnished a 3cd rip of t2 with dvd2svcd with 48000 audio and 352x576 video.
I believe it might be possible to edit the gop strucutre to be long in cce using dvd2svcd, check it out.
Baker -
When I play back videos on my Phillips and Apex DVD players made with the KVCDx2 1 CD and 2 CD templates using TEMPGEnc. The picture is great but stops for 20 seconds then plays for 5 seconds the audio does the same along with the video. This keeps happening through the whole video! I have tried the multiplex and burning at svcd2 with nero and the file did not play at all. Does any one have any suggestions! any help would be greatly appreciated
JoeGJoeG -
JoeGJoeG -
Check out www.kvcd.net and ask the same question, Kwag will provide a response that should work for you.
Aloha
Bud -
Kwag
Congratulations on your MPEG 1 templates the picture looks great. I always new more could be done with mpeg 1. However, The picture & audio are great but stop for 20 seconds then play again for 5 seconds. This keeps happening through the whole video! I use Nero to burn the CDs and I play back the videos on my Phillips and Apex DVD players. The templates I am mainly interested in are KVCDx2 1 CD and 2 CD using TEMPGEnc. I have tried the multiplex and burning at svcd2 with Nero and then the file did not play at all. Do you have any suggestions! any help would be greatly appreciated .
Thanks in advance
JoeGJoeG -
Did u try multiplexing and then remultiplexing using BBMPEG (select SVCD format) and the svcd headers will be applied. This seems to work on certain dvd players.
Yes I did but it still would not work. It seems when I start adjusting the bit rate the lower I go the better it plays.
What are your thoughtsJoeG -
http://www.kvcd.net/dvd-models.html
Dunno if your models are on that list, but if so then there may be some helpful suggestions.......... -
I HAVE JUST ENCODED GHOSTS OF MARS (1H.32M.57S) AT 80CQ WITH THE KVCD2 PAL TEMPLATE FILE SIZE WAS 955MB AND BURNT USING NERO ON TO A 99MIN INFINITI DISC.WHAT CAN I SAY BUT AWESOME.EVEN HAVE 6MINS LEFT ON THE DISC SO IT CAN ONLY BE BETTER.HAVE USED LOADS OF TEMPLATES BEFORE BUT NOTHIN COMPARE TO THIS FOR ME. THE DVD PLAYER IM USING IS A 99QUID DANSAI 852....
Originally Posted by spacemanJoeG
Pionerr dv-120 k DVD player
By aforisma73 in forum Newbie / General discussionsReplies: 1Last Post: 7th Sep 2011, 08:45 -
more than 120 minutes on 1 DVD
By icethekicker in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2011, 16:32 -
samsung dvd r-120
By wschw in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Oct 2008, 18:08 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 02:19 -
LG DVD-R 4.7GB/ 120 mins. 1-8X DVD Disc with 2:28.52 movie
By Gerald Sr. in forum Authoring (DVD)Replies: 4Last Post: 12th Nov 2007, 16:09
