Hello.
Ok, so i managed to rip the ac3 audio from a DVD, but i am not sure how
i make i work on my standalone DVD.
What needs to be done to the AC3 file before burning? (If anything) Should i burn it as an AUDIO cd? (I only want the AC3 audio on the cd.)
I tried to burn the AC3 wav directly lika a AUDIO CD, but i get no sound
and no indication on my amplifier that it would be a digital audio stream.
(Everything is connected the right way.)
AnonymousGuest
1) Either burn in DVD format (UDF/iso9660 bridge mode), if your player supports miniDVD, which it most likely wont.
2)Either use an app like BeSweet convert AC3 to wav formst, then burn as audio CD
3)Use BeSweet, convert AC3 to mp3 and author as regular data CD, and play as mp3 through your DVD player if your player supports mp3s.
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
