I am in need of a program that can stretch or shrink an audio file (WAV). What options do I have for this? I have a program that can cut the audio, but what I really need is something that can stretch it a little so that the audio matches my video exactly.
I've heard of GoldWave, Soundforge?.. I dunno if these can do it. Are there any others, and are there any freeware solutions?
Thanks for your help,
calamari
Well, I went ahead and wrote my own program to do it!
This (free) program makes it possible to speed up or slow down a standard uncompressed WAV file:
http://www.azstarnet.com/~jeffryj/wavspeed.exe
Unfortunately I'm beginning to think that adjusting the WAV isn't the way to fix my audio desync problems. I've been investigating the AVI structure, and I've found that VirtualDub writes a block of audio for about 11 frames of video. That's probably why sync problems can sometimes be fixed by extracting the audio out.
calamari -
Cooledit.
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
Cooledit isn't free.. but that's okay, because I made my own
Thanks,
calamari
Free program to stretch or shrink audio for sync
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2011, 20:51 -
Shrink (Reversed Stretch) 16x9 to 4x3 without black borders
By Paker in forum Video ConversionReplies: 4Last Post: 14th Sep 2010, 11:09 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
How to stretch/shrink subtitles
By las7h0p3 in forum SubtitleReplies: 0Last Post: 8th Oct 2008, 13:32 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 04:14
