hi all
ive been looking for a a piece of software that encodes wav audio to ac3 now for about three weeks but have come up with nuttin sofar please someone help a poor author !
is there such a piece of software in existence???
if so which is the best?
can someone tell me a way of multiplexing the ac3 file with a m2v???
nice one
rob m
Sonic Foundry used to sell an excellent AC3 encoder called Soft Encode but it is no longer commercially available.
Sonic's DVDit PE can convert your WAV files to AC3 but you are restricted to one or two channels only, not the full 5.1.
You can use TMPGEnc's mux feature to easily mux .m2v and .ac3 files together into one single .mpg file. The Dolby Digital audio track is preserved.
C h a o j i -
If you are lucky to find a software that will encode into AC3 for you, I would suggest you use Maestro (if you are lucky to have money to buy it) to multiplex these two streams. It will do an excellent job and will author a DVD for you as well. I understand you are talking about DVDs, since you mentioned AC3, and not about that crap which is called VCD, whatever letters it has in the beginning (like S)...
"There is always one more bug."
No bugs at http://www.iGorland.com -
igornt, SVCD may have a very good quality, it mainly depends on you and how you make it.
I have many of them with excelent quality.
Btw, it is impossible to use AC3 with (S)VCD. Only DVD supports AC3 sound.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Need new non-AC3Filter AC3 decoder from Expression Encoder
By CasanovaFly in forum AudioReplies: 17Last Post: 30th Jun 2011, 16:41 -
DVD-compatible AC3 Encoder
By roflwaffle in forum AudioReplies: 2Last Post: 14th Apr 2011, 13:42 -
How to encoder file with AAC/AC3 in TMPGEnc Xpress 4 (English version)
By roc255 in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2008, 16:57
